For those of you riding in loose rock conditions, what’s your technique on tight trail with loose gravel and broken rocks?
If that happened on fire roads where I can see the run off at the bottom, I would just sit back, bomb down and let the suspension soaked it up; but when it comes to twisting single tracks, I tend to wondered and got bounced around, eventually lost balanced to one side. It is tough to carry enough speed on top of the gravel and at the same time make turns with little traction, any recommendation to safely and gracefully pass through those nasty stuffs?
