1 - 10 of 10 Posts
· Registered
Here's my XCL after it's second ride. The first ride was interupted by the drive side pivot bolt coming loose and catching the bolts on the spider and as i'd left my tools at home i had to push the bike back, luckily i was riding a short loop at the time.
After the bolt came loose the first time, i put some loctite(242 blue) on it and it seemed to do the job, until today when it came loose again 10 miles into a 30 mile loop, luckily i''d got my tool's with me and managed to get the cranks off to tighten the bolt back up, but it meant another ride cut short as i wasn't prepared to keep stopping to remove cranks & tighten the bolt. People on here have said they use the red loctite, is that the 262? The spec sheet states that to remove the bolt after using this, requires heat (250 degrees) and hand tools. not sure i'd want to be doing that when i had to replace the bearings.
Other than the minor(ish) niggle mentioned above, i'm loving the bike (just spent 5 years riding a heckler) and if i could do more than 2 rides without the bolt loosening, i would be even happier.
· Registered
Nice bike, I like the blue. Haven't seen the blue color yet.
I had an issue with the same bolt coming loose on my Evo, and so did someone else here recently. The guys at Chumba should look into this.
I used the red lock-tite and have had zero problems since (about a year now). I have removed bolts that are secured with the red stuff without using heat, but it can be a PITA for sure. Having the bolt come loose on the trail is way more of a PITA though.
· Don't be a sheep
This has been a bit of a problem on all newer Chumbas. The latest frames have the "fix" with an extended pivot bolt and a lock nut on the back side. See if Chumba can hook you up.
· Registered
Discussion Starter · #4 ·
nice to know you can remove the bolts without resorting to heat after using the loctite red. Will be applying the red stuff tomorrow, as i need to get this sorted so i can stop worrying about it and enjoy the ride. The blue is apparently last years model.
· Registered
Discussion Starter · #7 ·
I was riding a large Heckler with a layback seat post. The XCL is a medium, it was the only frame left in the UK and luckily the measurements were very similar to the heckler. I'm about 6' 1" and could probably have gone for medium or large, but i do like a smallish cockpit and the medium XCL seems to fit me better than the heckler did.
· Registered
What we have found is that sometimes the bolts will come with a light oil on the threads, so the red loctite is prevented from doing its job. What we would recommend is to clean the bolt with alcohol before applying the red loctite. If you still encounter trouble, give us a call and we'll help you get sorted.
-A.
1 - 10 of 10 Posts
