Does the loose fitting tire on my velocity dyad make it easier to get flats? It's also a bit scary pumping them up since they like to blow off the rim when inflating.
I've had more flats since switching to 29er(2 weeks of riding thus far) than I did all last year on my 26" bike that was stan's for awhile then tubes at the end of the year.
At first I was using 29er tubes but both flatted out the first two days in Pisgah. After that I started using SPecialized turbo 26" tubes which seem to work fine besides one blowing out a few minutes in to a ride. Two others just went flat with slow leaks over night from I don't know what....really rocky terrain going extremely fast.
I'm being forced to run way higher pressure than seems to be necessary to keep from getting flats.
Should I switch to a new rim? I'm quickly losing my trust in the dyad and need to iron this out before some very long epic ride/races start happening in about a month.
