just wanted to know if there were any red flags about this bike I should know about for the 2008 model year.
TIA!
FRAME M5 alloy hardtail, fully manipulated DT, TT, SS, CS, ST w/ shared tube Mono-stay seatstays, new larger diameter/stiffer ORE DT/TT, disc mount, replaceable derailleur hanger
REAR SHOCK N/A
FORK Fox F90 RL, 90mm travel, air spring, rebound/compression adjust w/ lock out, alloy steerer
HEADSET 1 1/8" threadless, alloy cups w/ 10mm insertion, sealed cartridge bearing
STEM Specialized adjustable rise, 31.8mm clamp, 3D forged w/CNC finish
HANDLEBARS Specialized XC flat 31.8mm bar, 2014 butted alloy, 6 degree backsweep, 600mm wide
TAPE/GRIPS Specialized thin lock on grip, dual density
FRONT BRAKE Custom Avid Juicy 5 SL, hydraulic disc, 160mm rotor
REAR BRAKE Custom Avid Juicy 5 SL, hydraulic disc, 160mm rotor
BRAKE LEVERS Custom Avid Juicy 5 SL, hydraulic disc
FRONT DERAILLEUR Shimano M581 LX, 34.9mm clamp, bottom swing, dual pull
REAR DERAILLEUR SRAM X-9, 9-speed, mid cage
SHIFT LEVERS SRAM X-7, aluminum 9-speed trigger
CASSETTE FREEWHEEL Shimano HG-50, 9-speed, 11-34t
CHAIN SRAM PC-971 w/ Power Link
CRANKSET Shimano A/A/S 2pc custom
CHAINRINGS 22S/32A/44A, 4 bolt 104/64mm
BOTTOM BRACKET Shimano M542, 2pc custom for Specialized
PEDALS Crank Brothers Smarty custom for Specialized
RIMS DT Swiss custom for Specialized X420, 24mm w/ eyelets, 28/32h
FRONT HUB Specialized Hi Lo disc, 28h CNC flange and disc mount, sealed cartridge bearing, 9mm DT RWS alloy QR
REAR HUB Shimano custom M525SL hub for Specialized, 32h, alloy QR
SPOKES DT Swiss 1.8mm stainless, alloy nipples
FRONT TIRE Specialized Fast Trak Control LK, 26x2.0", 60TPI, tubeless ready aramid bead, dual compound
REAR TIRE Specialized Fast Trak Control LK, 26x2.0", 60TPI, tubeless ready aramid bead, dual compound
TUBES Specialized Ultralite, .6mm, presta
SADDLE Specialized XC MTB, hollow Cr-Mo rails, SL foam
SEAT POST 2014 butted alloy, single bolt setback, 30.9 x 350/400mm
SEAT BINDER Alloy single bolt, 34.9mm clamp ID
TIA!
REAR SHOCK N/A
