1 - 2 of 2 Posts
Currently riding a 2014 Giant anthem with stock fork which is a RS Recon Gold, set at 120mm
I like the shock action after having modified the compression damping for a more plush ride, but I do get a good bit of stiction and most importantly I think the fork is flexy.
I do have a 15mm axle.
Any suggestions on a 120mm fork of a similar weight that is going to be stiffer and have better small bump compliance?
Well if 120mm is good for you then pick up the RS Reba.
But if you want more travel go to the RS Revelation.
Easy decision.
1 - 2 of 2 Posts
