Good afternoon,
I'm looking to see if anyone has any insight into a tool for cutting zip ties while out on the trail.
Here are my requirements:
1. Must be as light and compact as possible - this will be a permanent part of my riding gear, so adding as little dead weight as possible is important
2. Must be able to work in very tight quarters - some tools have a cutting edge behind a set of mini pliers. I need something with a cutting edge that can be maneuvered in very confined spaces, so a cutting edge near the tip of the tool is important.
3. Must not present a safety hazard in my pack in the event of a crash - self-explanatory I think. There are plenty of flush cutters out there with pointed tips. I need something that either doesn't present a pointed tip, has a durable sheath, or has a concealable/retractable tip.
I currently have a Leatherman PS with integrated wire cutters but the cutting edge is recessed behind the pliers, which makes it very difficult to work with.
The Leatherman CS mini-tool seems like a possibility, although I'm not sure the scissors have the leverage and durability to be the solution.
I'm open to hearing about alternatives. Thanks!
