Look at some closeouts on 2008 models, and keep the travel in the 80mm-100mm range.
Does your Tass use v-brakes or disc...a lot of forks are disk specific these days so if your using v-brakes make sure the fork has brake studs.
I personally like the RS Tora 318 Solo Air for under $300 and it can be found for as low as $210 at Cambria Bike (disc only though). Models with brake studs can be had in the $260 range at other places.
