1 - 9 of 9 Posts
Its getting cold, but i still love to bike. Whats a good trainer that i can use as "entry-level" so i can get keep my legs in shape till the spring?
budget is: $200
P.S. i only ride recreationally, no racing. if that matters
I'd go with either a magnetic or fluid trainer. Fluids tend to be quieter, but the magnetic resistance is a really good work out. I'd stay away from rollers if you're a beginner as it takes a lot of paying attention to get used to them.
Discussion Starter · #3 ·
I am using the basic Mag trainer from CycleOps. It retails for $199.00 and I think I got it for just a little less. It is their entry level mag trainer and the only one "below" it in their hierarchy is their wind trainer. I used to have a fancier mag trainer, a Minura, with different levels of resistance. It was o.k., but I like the CycleOps basic one for its simplicity.
When I was looking at the new trainer, the guys I trust at my local shop--both a couple of pro mountain bikers--told me the basic mag is the best value and is what they use and the shop owner uses. They suggested the fluid trainers ride a little nicer, but if you really use them a lot they are more likely to need significant maintenance. I also love the ease with which I can get my bike in and out of the CycleOps--it takes about 10 seconds after you set it up the first time and it fits your bike. The Minura I had took me at least 5 minutes turning a crank with the bike falling again and again.
Unless you are training indoors a bunch, there is a lot to be said for just going simple. And it fits your budget.
bi-winning
louisssss said:
can i use the trainer with 26" bikes with knobby tires?
You can, but you likely won't want to. The the noise, vibrations, and tire wear are all rather undesirable.
force yourself to let it be your offseason. cross train until you can start riding again. Trainers work if you are racing because you have a goal to work toward. Riding on a trainer is not exactly fun.
I have a blackburn magnetic. it gets the job done. I am training to race but still am crosstraining with running.
cougarbait
fluids are quieter and offer better resistance. I use a Kurt Kinetic Road Machine fluid. before that I had a cycleops magneto that I ended up returning. for your purposes and budget, I'd stick with a magnetic. 26" no problem, knobby?? I'd throw a slick on there. I read some bad reviews on the blackburn. Go with a cycleops mag, or kinetic if you can afford one. Only kinetic has a fluid design that is impossible to leak.
1 - 9 of 9 Posts
