Steel FS 29er design and build
I'm designing and plan on building a mid travel 29er this winter. A few months ago I built a couple of hardtails (https://forums.mtbr.com/frame-building/steel-29er-hardtail-v2-0-a-1092402.html) and that inspired me to embark on this project. I'm shooting for something along the lines of a 160/140mm travel trail bike for the front range of Colorado. I already have a 160mm Fox 36 and a 215x63mm Fox DPX2 for this build and I'm aiming to have it clear 29x2.5" tires. The drivetrain will be 1x12 SRAM GX or NX Eagle and will be 148mm boost and use a 73mm BSA bottom bracket. Here are some geometry details (all dimensions are with the bike unsagged):
Rider height: 6' 2" (188 cm)
Rider weight: 150 lbs (68 kg)
Rider ape index: +3" (+7.6 cm)
Rider saddle height: 815 mm
HT Angle: 65˚
ST Angle: 76˚
Stack: 653 mm
Reach: 490 mm
Chainstay Length: 435 mm
Front-Center: 839 mm
Wheelbase: 1270 mm
BB Drop: 25 mm
BB Height: 350 mm (w/ ø755 mm tires)
ST Length: 450 mm
HT Length: 130 mm (plus 20 mm headset)
Fork Axle-Crown: 567 mm (160 mm Fox 36)
Fork Offset: 51 mm
Stem Length: 35 mm
My primary questions at the moment are about the kinematics. I want this bike to pedal very well as I enjoy climbing. I'm under the impression that I want to aim for just over 100% anti-sag at the sag point. The design as I've shown it below is around 130% anti-sag at 25% sag. Will this result in an overly insensitive rear end when climbing? And my leverage ratio goes from 2.75 to 1.9. Will this be too progressive for an air shock?
I'd appreciate any input you can add and any suggestions or comments are more than welcome.
HT Angle: 65˚
ST Angle: 76˚
Stack: 653 mm
Reach: 490 mm
Wheelbase: 1270 mm
BB Drop: 25 mm
ST Length: 450 mm
Fork Offset: 51 mm
Stem Length: 35 mm
