I am looking to build a short hose for the purpose of using one tubeless tire well seated to a rim as an air chamber to seat another tubeless tire.
I do a lot of solo rides far from help that would leave me with quite a hike out if I couldn't seat a tubeless tire. I have carried a pump and a couple of C02 cartridges, as well as a tube. In the few instances that I had to throw a tube in, it wasn't a great experience. In one cause, I actually couldn't get the removable stem out because of how tight it was (didn't have a wrench/plier and removing by hand was impossible).
I'd like to make a hose with double ends intended to clamp on either schrader or presta so that I can stop carrying C02 cartridges and possibly stop carrying a tube.
For home use, I was thinking of getting one of the common "boost" reservoir bike pumps, but if this works well, I could see myself just inflating one tire to max pressure and using the hose to rapidly seat the other.
The technical limitation I see is the way the presta valve is intended to work. It doesn't really want to give up it's air in a hurry. I could see adding a presta to schrader adapter and then the air head would push the valve on the "donor" tire so that air could flow to the other tire.
Has anyone made anything like this? Am I crazy?
It seems like a commercial product like this would have a place, especially considering all the boost reservoir pumps sold when most people trying to seat a tire and a perfectly functional air reservoir just a few feet away (the other tire).
