I'm no expert myself on old AMP/Mongoose bikes, but here is what I do know. The first generation of frames which have the twin downtube are known as the AMP B2 or if made by AMP for Mongoose, the Mongoose Amplifier. I believe they came out 92-93. They are also distinguishable from later iterations of the product by the F1 fork which has black steel legs vs. aluminum alloy legs. The AMP B3 has a single thicker downtube and the F2 fork which has alloy legs. I don't know too much about the B3 or the B4. I have a Mongoose F1 fork on an old 1994 Lightspeed Obed, because it is just about the lightest suspension fork I could find. However, with certain frame models and sizes, there is not enough clearance between the parallelogram mechanism and the downtube of the frame for the fork to turn without interference. I solved this issue on the size small Obed by using a Chris King headset and a +5 baseplate.Still Snoozin said:Thanks fro the correction - Someoneelse told me it wasa B3 - I really don't have the background to know myself. I just bought a "bike" years ago that a buddy recommended. I am enjoying learning more about it. I also am trying to guess what year it might have been made.
Does B1 mean it is older/newer ?? What years was the B1 made. What does B1,B2,B3,B4 indicate??
That helps. So enlighten us.muddybuddy said:Lotta incorrect info in this thread.
Thanks Muddybuddy. I made the changes to the post, so as to not spew out misinformation on this forum. So was there ever a production model called the B1? How did it differ from the B2?muddybuddy said:Twin downtube version is a b2 or mongoose amplifier the only difference being the stickers. This was the first readily available version. B3 was essentially the same but singledowntube. B4 had shorter seat stays with inturupted seat tube design. B5 was a linkage design similar to the late 90s FSR bikes.
Fork names always start with F not B.
I'm not sure, but I would assume there was some version or maybe just a prototype series before the B2. Maybe the great Oracle of Amp knowledge knows.datasurfer said:Thanks Muddybuddy. I made the changes to the post, so as to not spew out misinformation on this forum. So was there ever a production model called the B1? How did it differ from the B2?
Wrong. Mongoose switched to their own frame in 95 and called it Amplifier2.DeeEight said:the Mongoose Amplifier 2 was the same frame as the Amp B-3 except it came with a Risse supplied rear shock instead of the Amp thru-shaft shock. The colour of the Amplifier 2 was a blue main frame with polished swingarm instead of the black main frame of the Amplifier 1
Glad you posted the amplifier 2 pics. I couldn't recall if it was a mac strut or not, but I knew it was not an amp research frame.DFA said:Wrong. Mongoose switched to their own frame in 95 and called it Amplifier2.
It was the same rear end later used by Litespeed for their Hiwassee
