Start doing lots of bunny hops, you'll build the muscle tone... besides that, maybe a Boxxer is lighter(?) I'd have to research each fork to know for sure
Yeah that's what I'm leaning toward at this point. I definitely need a dual crown on a GG/DH, but the way i ride I don't need anything huge like a coil fox 40.Yeah, an inverted fork is always at a disadvantage when it comes to torsional flex. Exotic engineering can solve that...but that same engineering can be put towards making a standard fork better/lighter. Was it Formula that was recently prototyping a new enduro DC? Anything coil is going to end up around 8lbs for that kind of fork IMO. But a custom tune might go a long ways with an air spring.
Avalanche hybrid coil is lighter than full coil...but the oil bath probably makes it as heavy as any other coil DH fork with a closed cartridge.Yeah that's what I'm leaning toward at this point. I definitely need a dual crown on a GG/DH, but the way i ride I don't need anything huge like a coil fox 40.
It's an exercise in futility. It basically allows your competitors to undercut you, either in weight, rigidity, price, etc. Almost anything is possible with enough money or exotic engineering, but it's just not the best way to make a fork unless you are significantly more than 8" of travel, where right-side-up fork bushing overlap is insufficient. A lot of smaller makers made inverted forks in the 2000s, because they are much simpler to manufacture. Foes, Mr. Dirt, Risse, Hannebrink, Avalanche, White Brothers and others. They don't require fork lowers castings and can be done by CNC/lathe. About the best implementation I've ever seen was the RS-1, with a one-piece carbon crown/upper assembly As a single crown inverted fork, it's even MORE flexy than a traditional inverted, but using a one-piece CF unit on a dual crown version could show some promise...but again, exotic manufacturing.Looking forward to engineering that makes an inverted fork torsionally stiffer and lighter/ better. I guess manufacturers are not there quite yet but hopefully we are getting closer!
Your questions are irrelevant to me replacing an 8 lb fork with something lighter.look a fox 40 isn't really that heavy ....
so here are the questions -
do you have an injury or anything physical defect ?
Are you old or too young, short ??
If you really want to ride - then do push ups, sit ups, pull ups, back, bench press, curls, lats....or better just hire a trainer and get an exercise plan......I am old and was still riding with a Heavy Emerald up front and still threw that around....You can do it too.
LOL: The fact SMT still suffers from testosterone poisoning and I should too?Ahhhh the mtbr of old...
Nah, but whenever someone comments about the good old days, I chuckleLOL: The fact SMT still suffers from testosterone poisoning and I should too?![]()
if this was true then it wouldn't be as big as a problem, so the questions were relevant because it really shouldn't be that big of a deal unless you have physical defect ( a fox 40 is just under 7 pounds)...but lets not go back and forth here because the end part was a tongue and cheek joke.....telling someone who's been weight training for over a year to STFU and push-up is counterproductive.
Because i have an enduro bike. I can handle more laps and not be beat up as much on the DH rig vs the Enduro.if this was true then it wouldn't be as big as a problem, so the questions were relevant because it really shouldn't be that big of a deal unless you have physical defect ( a fox 40 is just under 7 pounds)...but lets not go back and forth here because the end part was a tongue and cheek joke.....
For your riding style ( you said the way you ride you don't need a big fork) ....why don't you put a lighter single crown fork on like the DVO Diamond they weigh like 4.7 pounds or just sell that bike and get an enduro bike .....
