1 - 14 of 14 Posts
Need some help here
I am looking for 2.3 tubless tire like the Nevegal or the Rampage
Does any one have any suggestions. I know about the Nevegal 2.3
This tire is going to replace my Speciliazed Eskar 2.3 up front on my Enduro.
I like Monkeys
Well I was going to suggest the Eskars. I love mine, I run them at 30 psi and have had no problems with pinchflats, etc. And I found them light and fast rolling. What's wrong with the eskars.
Discussion Starter · #3 ·
The Eskars have a dead spot when you lean them over. They get good traction to a certain point, then slide a bit then grap again if you keep leaning them over.
I have not tried running them at 30 PSI, I usually run them about 35PSI
i have run maxxis ignitor 2.35 LUST. light tire....770g, been happy with them. trying some schwalbe racing ralph 2.25's right now. lighter. seem to be good so far. lugs not as tall in the center as the ignitor.
I like Monkeys
I haven't noticed that at all. Try them at 30. I did it on one of the rockiest places in Va without a pinch flat problem. The tire works good around 35 psi, great at 30. Still fast and great traction.
I’ve had nothing but bad luck with the Eskars running tubeless… 1st ride out, slashed the sidewall on a rock. Utilized Specialized’s unconditional guarantee, and slashed another one about 5 rides later. Running 35psi, which I think is too much to be running to take advantage of tubeless capabilities, especially with that much volume.
The Eskars are off my bike now, and I’m waiting on some (non-UST) Maxxis Advantage 2.25’s. Hopefully they hook up well on my 819’s with Stan’s fluid.
Premium Member
Depending on your riding:
Schwalbe Fat Albert 2.35 UST, good for mixed conditions, no mud with rocks.
Schwalbe Big Betty 2.40 UST, apparently also good for mixed conditions and has a strong casing.
Forget work- let's ride!
All Mountain Rider Here.......
Anyone have any ideas about which ones have the thickest sidewalls? :confused:
I love tubeless and want to go back but rip up the sidewalls way too soon (New England).
My last set of Eskars blew out when I was going over a rocky outcrop and I fell and got banged up. The sidewall had a huge hole in it. Imagine what would have happenned if I was landing after getting some serious air! :eek:
I'd like to stay away from anything doouble wall and bigger than the 2.35 because in my experience they roll like truck tires that I can't pedal uphill.
I am now using Schwalbe Albert 2.25 UST with snakeskin and they have been holding up very well in the sharp rocks around here. Previously, I had a Nobby Nic UST that only lasted half a dozen rides before the sidewalls were destroyed.
1 - 14 of 14 Posts
