1 - 3 of 3 Posts
I am 6'4" w/ a long torso. All of my last 1/2 dozen or so frames were XL's w/ top tube lengths that measured (actual) about 23.75". Seat angles were similar ranging from 71*-73*. Climbing or pedalling the flats I prefer an upright position from a straight Thomson post and my seat slid almost all the way forward. Run an 80mm stem. As of late, when descending I feel like I am on a tri-cycle . Came across a couple of newer trail / AM frames that sport 25" (actual) top tubes. Will I feel better on descents ? Worse for pedalling flats / uphill ? Thanx
Shaman
I am 6'3' and the perfect top tube length for me is 24.5". My Enduro XL has a 25.2" (I think) and it feels a little cumbersome while my Stumpy is 24.5-24.75 and feels just right (both with a 65mm stem). I found the 25.2 top tube good for climbing but too stretched out for descending. Being an inch taller than me w/ a long torso it could feel perfect for you, especially if you shorten the stem a hair. The biggest problem with the long top tube is switch backs, the wheel base starts getting really long. For me the trade off is worth it though.
Underskilled
losing speed on a switchback is more than worth the spedd gained EVERYWHERE else.
I also find myself more balanced on switchbacks, so kind of even on that point.
6'7 with a 25.25" TT
1 - 3 of 3 Posts
