I can’t comment on the forks you’re considering but on my hardtail I run a 140mm Pike that I converted to coil with the Push ACS kit and can say that I enjoy the fork’s performance more than when it was air sprung: it’s not as divey, a bit more supple and also more composed. However it’s less tunable given that you can’t play with air pressure or volume so your mileage may vary depending on your needs. Choosing the right spring is key!
