I have done some searching on the forums and haven't found anything to match this question specifically.
I am looking at getting a Blur LT and at 6'1" I fit in the large frame with a 120mm stem or the XL frame with a 90mm stem. My question is, how does a bike ride differently in these two situations?
I am guessing long stem will make climbing easier but descents sketchy, and a long tob tube will make descents seem a bit more stable. Is this correct?
What are the ride tendencies if I go for the shorter top tube and shorter stem combo?
I ride up and down with a lot of technical ascents and descents with some low ground obstacles and stunts if that helps.
