1 - 20 of 84 Posts
...I will attempt to document the process.
I received the Medium pack today & am proceeding to build it up "as is" to get a feel for the frame itself. I will then begin to experiment with some different configurations over the next couple weeks to determine my ideal build. Along the way I will try & add some thoughts & data points as they make themselves available.
.....now to build it up!
Lay off the Levers
Man! I had no idea the DHXc added that much weight.
On a side note, now I gotta sell my yellow Alpine scale and get one of those Spanky RED ones.
This should be a fun project. Enjoy!
Discussion Starter · #3 ·
....ready for a test ride. Bad news to the Med. Pack crowd....the 66 SL does make contact with the downtube. It just touches, but enough to leave a mark in the paint. Looks like I will have to go for the Ventana race myself....anyone know where to get one?
Gratuitous Basement Shot
PS. Ssinga, I'm in the same boat as you...I need a 0-300 PSI pump to give the DHX air a run. 'Zocchi only goes to 200!
Larry had 6 in stock Monday and they all sold by Saturday! Maybe he's already ordered some more?
Either that or SSINGA has a box full ;)
Bodhisattva
Uhhh.....Ventana? ;)
Mtn High had a couple on the shelf. I snagged a 7mm and I saw a couple of 3mm races.
Edit: Opps. Missed Paul's post and I haven't been to MHC since Weds. Ventana then.
nice pack
Thanks for posting the frame wts. I'm going to be building a pack soon as well, (also white w/ DHX air) only i'll have an 05 z1up front. It's cheaper and I think it will be just fine for me. Sounds like a few of you guys are Front Rangers, I'm gonna have to keep my eyes peeled for other Turner's out on the trails :)
Happy New Year!!!!
Discussion Starter · #10 ·
...a shot of the 5 Pack.
...just bouncing on it in the basement, it seems very strange. Somehow the coil feels much more firm on the 5 PAck then it did on the 5 Spot. Need some trail time to confirm...
Discussion Starter · #12 · (Edited)
....Urban Legend Caught On Film!!!!!!!!!!!!!!!!!
Ladies & GentleHomers, I present to you the ever-elusive JACKALOPE!
...amazing feeling ride! Exactly what I have been trying to accomplish. Very stiff & burly feeling, yet weighing in at a svelte 33.03 lbs in this configuration. I must say, early impressions on the DHXa are very favorable.
Baked Alaskan
JN -- is the front triangle switch a pain in the rear?
I've been thinking about dropping some coin on a Pack front triangle and either switching front ends depending on where I'm riding or maybe just selling off the Spot front and roll with the 5-Pack for good.
Are your plans to switch back and forth or is the frankenturner a permanent setup? How much travel are you running on the 66?
Smooth ride BTW, the white triangle bookended by the black fork and rear is killer.
Discussion Starter · #14 ·
...I plan to switch off the rear tri's for different terrain. You really need the spot rear stays to achieve a XC-ish feel with the 5" setup. My longterm plan is to sell the Spot & buy the TNT rear spot stays & rocker. I really like the 2 very different feels the setups achieve. FWIW....I basically swapped the components from the Spot, added the 66Sl (a tad heavier fork) & with the DHXa swap I ended up with a 1/2# lighter rig with the RF5. 66 is set to 6" with the 6 x 6 setup & 5" with the 5 x 5 setup. Eventually, the front tri will be PC'd black (of course). White is cool & all, just not my motif ;)
BODYSNATCHER
weight
jncarpenter said:
...a couple weights of interest:
Large Spot front triangle = 3.59 #
Medium Pack front triangle = 3.66#
...surprising but true! 1.12 Oz. difference....sweet!
....weenie! :D
1 - 20 of 84 Posts
