Anyone running long cranks, 180s, 190s? What are your ride impressions? Considering Zinn 195s, maybe Surly 180s. I feel like my 175s are too small. 6'5" on a '10 Sultan running XX.
Cheers
Cheers
From the above article:burgundy snake said:I appreciate everyone's input. After a bit of fit theory and crank research, number crunching and biasing for ride type, seat angle; rail position, shoe size, cleat position, XX gearing, and bottom bracket height, I've determined that I need 200mm cranks. The most compelling literature I found was written by Zinn. http://zinncycles.com/Zinn/index.php/archives/1399
Also, as some have pointed out, we are guilty of becoming accustomed to what we ride and changing will take a little getting used to. Therefore, it may be a little while until I get my bike dialed and I adjust to the changes; I'll try to provide an objective ride report when I can.
Ride On! :thumbsup:
True. My bike came with 175s and I swapped on 180's. Doesn't sound like much, but I definitely have more strikes.Jeff in Bend said:From the above article:
3. A stock mass-produced mountain bike will probably not have a high enough bottom bracket to ride on technical trails with a crank any longer than 175mm or perhaps 180mm.
I just just did the same but haven't been able to ride with them except around the hood. Other than the strikes what's been your experience?NYrr496 said:True. My bike came with 175s and I swapped on 180's. Doesn't sound like much, but I definitely have more strikes.
That's a great point. I just swapped the rims on my bike to Salsa Gordos and they changed the profile of the tire significantly. The bike is absolutely a little higher. I just had my first ride in over a month today. Too much snow. I didn't realize it at the time, but I had zero strikes.Pitch said:x2 on pedal selection dictating the frequency of pedal strikes... but not crank arm strikes. I ran platforms and Mallets for a while, but not anymore.
Tire selection can also change your bb height substantially as well. I run some large volume tires (2.4 Purgatories and Ardents among them), that can easily raise your bb height by 5mm or more to accommodate longer cranks.
Zinn has sold you a bill of goods and he makes a good living doing it. If you consider his "literature" compelling, why haven't you looked for even the most rudimentary data that suggests it is true? Zinn won't offer it no matter how badly he wants to. Other than formulas that have no data behind them, what has led you to determine a length of 200mm?burgundy snake said:I appreciate everyone's input. After a bit of fit theory and crank research, number crunching and biasing for ride type, seat angle; rail position, shoe size, cleat position, XX gearing, and bottom bracket height, I've determined that I need 200mm cranks. The most compelling literature I found was written by Zinn. http://zinncycles.com/Zinn/index.php/archives/1399
Ride On! :thumbsup:
Can you provide where we could find these test that say 150mm crank arms are really big?craigsj said:Zinn has sold you a bill of goods and he makes a good living doing it. If you consider his "literature" compelling, why haven't you looked for even the most rudimentary data that suggests it is true? Zinn won't offer it no matter how badly he wants to. Other than formulas that have no data behind them, what has led you to determine a length of 200mm?
I agree with Pitch who said there is "a rule of diminishing returns with really big crank arms". Testing has shown "really big" to be about 150mm surprisingly. We all get long enough crank arms stock on every bike. There's a lot of confirmation bias regarding long crank arms since there's so many claims that proportional cranks are needed. You won't find a single objective test that shows any value to long cranks though.
Here is something I've linked to a number of times: Martin crank length presentation. This is a slide presentation that summarizes some studies on crank length.Jeff in Bend said:Can you provide where we could find these test that say 150mm crank arms are really big?
I would like to read them. I don't think I would ever go to what Zinn recommends for my leg length because I don't want a BB that's 15" high. I'm going to try some 180's this season and see if I feel an advantage, but I'm keeping my 175's just in case. I have a 38" inseam.
That presentation wasn't put together very well, but I got the jist of it. What I've seemed to notice that all the data gets measured for peak efficiency or output but I've not seen any tests were someone is measureing power at real slow cadences were no one reaches max cadence output or pedal speed. Like grinding up a steep hill in your lowest gear.craigsj said:Here is something I've linked to a number of times: Martin crank length presentation. This is a slide presentation that summarizes some studies on crank length.
One of the studies quoted looked at metabolic costs at submaximal loads (30, 60, and 90 percent). The test methodogy included allowing cyclists to pick their preferred cadence to avoid biasing against short cranks (a failure in some testing). That means, of course, that there's an assumption that you will have the right gear for the task, not one that doesn't allow for the best cadence. I'm not sure what it says about running out of low gears, but what it says to me is that I shouldn't let that happen. I know that shorter cranks need lower gearing so I provide it.Jeff in Bend said:That presentation wasn't put together very well, but I got the jist of it. What I've seemed to notice that all the data gets measured for peak efficiency or output but I've not seen any tests were someone is measureing power at real slow cadences were no one reaches max cadence output or pedal speed. Like grinding up a steep hill in your lowest gear.
Regarding leverage, read what Sheldon Brown says. I've tried to explain this a number of times here on MTBR but it's never received well. Sheldon Brown is more respected.Jeff in Bend said:This is what seems logical to me. If I have a 38" inseam compared to someone with a 32" I would use less% of my total range of motion if we use the same crank length. If we both used the same % of our range of motion my cranks would be longer. A longer crank would give more leverage than a shorter crank and more tourqe to the rear wheel when in the same gear.
