Extralite The Post UL2 XL
27.2 x 400mm 175-177g
I use Maxm bars and do like thier stuff, but sadly their stuff is no longer in productionJag said:The new MaxM carbon seatpost. My 27.2 x 400 mm has a claimed weight of 175 grams and a digital scale verified weight of 180 grams. I hear these posts are hard to find...
My hardtail has a Thomson 27.2 x 410 and it is the standard as far as strength and durability is concerned. The MaxM carbon post has been very nice however it is more flexy then the Thomson.
Hope this helps.
Jag
bike_freak said:Alright, so i was happy with my Carbon composite post until i found out it was too short for proper leg extension. So currently i'm running one of those Kalloy seatposts at over 300grams.
It needs to be 390-410mm in length, a straight post (no seatback or very little of it), not stupid expensive and strong enough to be dependable even when run at a long length.
So any reccomendations BESIDES the thompson 27.2/410mm? Looking for something lighter if possible.
Thanks for any help, and if this has been asked before, just guide me in that direction
And if it matters, it's for a NRS composite Small, And i weigh under 60kg, but not the easiest on parts (bent Ti rails, flat spotted my DT rims...).
Check out the Bontrager XXX-Lite Post. Light and long -bike_freak said:Alright, so i was happy with my Carbon composite post until i found out it was too short for proper leg extension. So currently i'm running one of those Kalloy seatposts at over 300grams.
just in case you didn't see what he is looking for:MaLóL said:kcnc
155gr 350mmx27.2mm diameter
price: 55€ on german ebay
UNBEATABLE!!!!!
thanks for the correction nino, you are always so helpful...nino said:just in case you didn't see what he is looking for:
...."It needs to be 390-410mm in length"....
you are welcom. as always i'm your expertMaLóL said:thanks for the correction nino, you are always so helpful...
Anybody have saddle time yet on this post? I'm a 190 lbs. with gear and ride techy XC but don't do too many jumps. The $$$/weight ratio seems great but not if you endanger your nads.jceahodges said:Does anybody have time/experience on one of these seatposts? I'd like to get the New Ultimate, but a little too $$$$, so I'm considering getting the KCNC. Seems to be a good value for the dollar, but I feel a little unsure at the moment just how reliable/sturdy this post would be for technical XC riding (no jumping or hucking). Any feedback would be extremely appreciated. Thanks in advance!!!
I just bought one of these. It appears very nicely made and the adjustments are very easy, but the weight was 236gr for a 27.2 x 400mm, so it is a little heavier than advertisedpktrekguy said:Check out the Bontrager XXX-Lite Post. Light and long -
http://bontrager.com/Mountain/Components/Seatposts/5722.php
