My recommendation would be for folks to ignore the advice above. It's misguided on a number of fronts.NateHawk said:Also, a lot of your clip transitions are very abrupt jumps. Smooth them out some.
You probably don't need 1080p HD, to be honest. Too much time waiting for it to download, not enough time watching. Record in a lower resolution and you'll take up a bit less space for storage on your machine.
Just admit it, its my legs that are so sexy which is why they grabbed your attention.NateHawk said:I want to see more of what's in front of you, not your knees (and even your shoes in some cases). The repetitive motion of your knees draws my eyes away from what you're riding.
One thing on the clip transitions, what I was trying to do was separate different parts of the track. So for instance, if it was the same climb I would fade into and out of each clip and if it was a new section I broke it up with some blank frames. I think this is a bit easier on the eye than just going straight into the nest clip (I was given that as a tip after my last video and I think it works well).NateHawk said:Also, a lot of your clip transitions are very abrupt jumps. Smooth them out some.
On the mounting issue, I hear of a lot of folks flipping the camera upside down to achieve a higher view with the chesty mount.Ben_M said:Just admit it, its my legs that are so sexy which is why they grabbed your attention.I have to agree, it kinda looks like im riding with my legs around my ears. The camera is adjusted as upright as possible so im thinking of trying to move it higher up my chest and see what that does. Other wise I will have to adjust the mounting plate.
I think ill disagree with the recording in 1080p HD but, normally I embed the video in non HD and let the user decide weather he or she wants to watch in a beter format. This time I embedded using HD so it takes longer to download. I shouldn't do that as I have a rather slow internet connection so I don't really like it when other people do it.
Thanks for the comments guys. Ill look out for your vid's and try and reciprocate Nate.
Did you try mounting it upside down? You can angle the camera up any degree that way, just set the camera in UPd mode.Ben_M said:The camera is adjusted as upright as possible so im thinking of trying to move it higher up my chest and see what that does. Other wise I will have to adjust the mounting plate..
