I did a quick search, but only found threads about lateral play.
So how common is it for a centerlock hub/rotor to linear play?? I dont think that its noticeable during the ride, yet. Mostly its just when i am stopped, grab the brake and rock the handlebars back and forth. I took the wheel off for a closer inspection, and while both the rotor and hub splines look clean and in perfect condition, its clearly visible that they are not a snug fit. It began with a XT rotor on an XTR front hub after about 300 miles of use. I swapped out for a magura centerlock adapter/rotor, it seemed nice and tight to start, but after 50-100 miles it is in the same condition as the XT rotor. Is my hub screwed?? Is it possible to replace the centerlock?
