1 - 11 of 11 Posts
- So we got her built up - Matteo from Gamut was nice enough to send us their newest chainguide - works great with the E-type front derailleur - even without ISCG mounts - although we did need to play around with it a bit - Btw, for those of you cutting your brake lines - generally for a small or medium XCL or VF2 frame - you are looking at 750mm for the front and approx. 1275mm for the rear - so if you are cutting them and your measurements are around those numbers - you should probably be ok.
Full build report and more pics to follow -
Discussion Starter · #3 ·
more pics -
Went with:
Hope Mono4 steel braided cables lines - saw blade rotors
Chris King Hubs with DT Swiss spokes and rims
Shimano XT cranks
Gamut Dual Ring Guide
Fox Float RLC FIT 15mm
SRAM x.9 rd and shifters
Sunline bar
Thomson stem and post
Hope seat clamp
CHUMBA saddle and grips
Graphics need to be applied by hand - so custom order only for now.
Discussion Starter · #6 ·
02Bullit said:
Looks friggin sweet. :thumbsup:
Are the graphics available separately? Might have to find somebody to buy mine so I can get the new one. :D Are they available with the same build kit?
Yes - the graphics will be available separately. - Yes - we can provide this build kit for you also.
A.
1 - 11 of 11 Posts
