1 - 20 of 267 Posts
What are the lightest rotors out there or a good combo of light/strong? I have G2 Cleansweeps right now (160/185) running on Avid Juicy 5s. I am going to convert to 160/160 and want some lightweight rotors that will work with the Juicy 5s. I like the bling of the Hope Floaters. Will they work?
bike rider
Scrub Components are the lightest I've found but the looks are an acquired taste. The new magnesium are going to be even lighter but I think they look better. Did I mention that they're Crazy expensive? $145 per for the standard rotors and I'm sure even more for the new ones.
The alligator serrated rotors are light and all steel, so stop well. Also the hope alloy centre rotors (from the mini X2 pro) are good too.
formula rotors are pretty light - I'm considering some for my AM bike, saves 40-50g each over XT rotors if my info is correct (180mm).
Best bank for your buck is probably the alligator serrated from pricepoint for $15. I've heard the Formulas are better in terms of pad wear but have only used the alligators.
The MTB Lab
Ashima AiRotors! Alligator wind cutters can give pulsing issues, so I no longer use them.
I tested the Aries for a week out in California on some steep terrain, and they were pretty much useless, verging on scary. The Ashima AiRotors are monstrously powerful in comparison.
That's a strange one - i've been very impressed with the Aries rotors. Using them with Superstar Gold sintered pads and noticed a massive increase in braking power over the standard Hayes rotors. I swapped out the rear from 185mm to 160mm at the same time too, so i was actually expecting a bit of a drop in power due to this :confused:
Anyone know any lightweight centrelock rotors? I need a 140mm one
MI_canuck said:
Avid Clean Sweep X (rotor from the XX group)... no idea on weight, but aluminum hub spider (so I assume lighter than Clean Sweep G3's), and decent price (compared with the likes of Scrub)...
There was a report here that Sweep X 160mm was 97g compared with 104g for regular G3 it replaced.
1 - 20 of 267 Posts
