Before I get flamed for starting another 66SL thread, I've done a ton of searches (shocks, turner forums) but haven't found this info yet. I'm fairly familiar with how the fork works but haven't been able to find much information on lighter folks running the 06 66SL.
What is the minimum PSI required in the positive air chambers? Can you have 0 PSI in there and not have any air or oil leaking problems?
I also read a thread where someone said that you CAN run 0psi in the positive and pump up the PAR higher to get a plusher ride. However, I wasn't sure if the poster was confusing the 06 and the 07 66SL which I understand has differently behaving internals. Just need a confirmation on this before I try it and blow up my fork.
By the way, I'm about 145-148lbs. suited up and currently running the fork at 150mm.
