Lightweight frame?
976 Views 5 Replies 6 Participants Last post by  32seventeen
At present I run my SS off of a Supergo Aluminum frame with vert dropouts. Light and stable. The gearing I run happens to fit the chain perfectly, and I do not have to have any tensioners. Great setup... BUT: I want to change the gearing, which will result in my having to use a tensioner, which I hate. I would actually buy a new SS specific frame if it came to that. All the 'low end' stuff: Surly, etc...is heavy steel. The beauty of SS, to me, is the weight/ simplicity. Any 'inexpensive' lightweight SS frames out there?
Can vert dropouts be welded/ adapted to my current aluminum frame?
1 - 6 of 6 Posts
Coupla few options for you.
The White Industries Eccentric wheel will fit the bill. Reasonable weight w/o the hassles of a spring loaded tensioner.
or you could get a new frameset...i know of a fab alloy 29er...
or you could get alloy sliders added to the mix, if you know a good welder Sliders
Welding sliding drops to a Supergo frame seems. . .well. . .I personally wouldn't bother.
The Eno Hub is probably the lightest option. I wouldn't be surprised if it were lighter than the hub currently on the bike (unless you are using a non eccetric ENO). 224g.
To me, part of the beauty of singlespeeds is that you don't have to weenie out on the frame to have a very light bike.
You can change gearing, just keep the total # of teeth the same.
32x18 ---> 33x17 or 30x20. This setup, anything totalling 50t will work.
Small chance that it will do what you need, but a chance nonetheless.
In the end, an ENO hub might be easiest.
You ride an alloy frame already, so why not one of these?
What is your current gearing and what do you want to change it to?
1 - 6 of 6 Posts
