J
Jeff_FLG
·Guest
I'm considering evening rides, since daytime is out due to work, after work/early evening due to kids, and early mornings usually due to inertia; even weekends lately seem increasingly committed. I discussed a bunch of lighting options from Niterider at my LBS and would welcome any other advice.
Specifically, other than the obvious spec differences, what are the relative advantages of a single-lamp model (like the Blowtorch) and dual lamp models (e.g., the Digital Pro)? It seems that the dual lamp might be better -- if the beams are parallel -- as the "landscape mode" illumination would better replicate your natural field of vision.
Also, if you have one light, what's better -- bars or helmet? LBS says bars, which seems reasonable since the bars are either (1) pointed where you want to go, thus illuminating the trail, or (2) not pointed where you want to go, in which case your problems might go well beyond the quality of your lighting.
Thanks very much for input from anyone who has some experience with this. I'd like to get lighting that will initially get me around the forest roads near my home, but which could also do the job on more serious nearby singletrack, should I get that adventurous.
