Lightest 1 1/8" adpter for lefty
1249 Views 12 Replies 6 Participants Last post by  pumpkinbiter
Can anybody make an advice for this...
There is a lot of adaper on e bay but which one is lighter? Or is somebody doing something in the forum?
1 - 13 of 13 Posts
When will we see your own frames :)
How can i get one of this? Can i use it with all headsets?
Mattias:
You have to show this one as well: No need for a starnut, it's integrated. Saves me 4 grams over the one in the picture above. The Gum Gum that I'm using is 8g, so that steerer with Gum Gum would be 86g, and the one you made me (below) with bonded in aluminum insert is 82g:
Blown Civic, you are correct, Ionly wanted to show the lightest available.
78 grams was your 202mm steerer tube too.
Contact me either in PM or direct: Mattias @ hellore.se
Every steerer tube is different depends on what you want included and your weight and riding style.
I have an S-works M5 rame and Scale 10 frame but i am looking for a Flash F1 Alloy bike... I have not decided yet...
If I decided to build up Scale 10 frame i will contact with you for steerer tube...
And also are making lighter lefty Steerer tubes for 1.5" frames. How much is it weight? I saw on Eliflap s bike he uses Scalpel and lefty with Syntace F99 stem are you doing something like this?
He is using my steerer tube, a older version in 96 grams something like it.
He will receive a updated steerer tube.
I did a steerer tube for a Specialized with 1.5 steerer tube, shipping soon.
The most tubes I sold is from 78-125 gram range.
Sounds great:thumbsup: :thumbsup: I would like to have one:D :D :D It doesn\t have aluminium bonded insert for the topcap isn't it? I will not put anything in it while riding I think, Leaving it empty is the lightest option! ;)
Ninko, that´s your steerer tube :)
Darn it - I should have weighed my Project 321 adapter before I installed it... oh well maybe it's posted somewhere on their website? http://www.project321.com/bikeleftybonded.php
It's an alloy steer tube, so maybe a little heavier, but I think I'll stick to alloy for a steer tube on a MT bike for now any way...
I have a Project 321 steerer tube at my shop.
Uncutted about 200 grams if I recall, my tube at 78 grams is at least half of that when the P321 tube is cutted.
But the P321 does not come with a weight or riding style limitation.
Hi guys, the Project321 steerer weighs 161g when cut to the same length as the
stock cannondale tube. And Cactus is correct there are no rider weight limits or riding style restricitons. Your lefty will fall off before this steerer tube breaks:D
1 - 13 of 13 Posts
