Considering a set of lighter wheels for my Stache (2018 Stache 5, currently running 29x3.25" tires).
Some background / assumptions:
From past experience with Vibrocore bars and stuffing my Fasst Flexx bars with foam backer rod, I'm curious about similar tech with rims. As far as I can tell, though, the only plus rims that are foam injected are Atomik's Chubby Plus and those are 27.5+ only:
atomikcarbon.com
I did come across COPRO as another builder with foam injected wheels, but it looks like those are only 30mm internal width and ~$600 each:
Berd spokes + Kappius rims seems like it would be the "best" possible option for weight & quality.
For value, though, would slightly heavier carbon rims + Berd spokes be a better option than Kapius rims & standard double-butted spokes?
- The Duroc 50 rims are currently listed on the Hayes site as 590g and I'm assuming the stock hubs are probably on the heavy side, so most anything I upgrade to is likely to reduce weight.
- I'm seeing other references to 655g for weight on these as well...
- As long as I'm running 3.25" tires I should probably keep with 40+mm internal width and it's better not to try to save weight by going narrower.
- I'm about 160 lbs, do mostly XC riding, am just starting to figure out getting wheels off the ground, and haven't managed to damage any wheels yet.
- I'm a sucker for trying out new technology / gimmicks to improve comfort
- Current bike has Fasst Flexx bars w/ 12 degree backsweep, Revgrips, and a Nexride noseless saddle (cut down to 140mm width) on a Chinese Rinsten spring clone
- No matter what I upgrade to, my own level of skill and fitness will still be the limiting factor for me on the bike.
- Light Bicycle RM29C15
- ~100g savings per wheel
- 490g +/- 20g
- ~$220 / rim shipped
- RM29C15 Carbon MTB Rim - Light Bicycle
- Carbon Bicycle (various 50mm options)
- 490-510g +/-20g
- ~$230 / rim shipped
- Hookless XC 27.5er(650B) &29er mtb 50mm wide carbon rims tubeless compatible - Hookless Rim - Carbonbicycle Online Shop
- Nextie Crocodile 29+ rims
- ~80g savings per wheel? (only comes in 32H, which might lead to more weight!)
- ~510g
- ~$275 / rim shipped
- [NXT29CD50] [Crocodile] 50mm Width Carbon Semi-Fat Plus MTB 29+ Rim [Tubeless Compatible]
- Nextie NXT29XM46
- ~120g savings per wheel
- Only 40mm internal width (enough for 3.25" tires?)
- ~470g
- [NXT29XMA45] PREMIUM Asymmetric 45mm Width Carbon Fiber 29" Mountain Bike Clincher Rim [Tubeless Compatible]
- KR-29-XCW from Kappius
- ~150g savings per wheel
- 435g +/ 15g
- $700 / rim shipped
- https://www.kappiuscomponents.com/collections/rims/products/kr-29-xcw-rim
- Berd spokes
- ~50-100g savings per wheel
- ~$280 for a 28H wheel
CHUBBY 43 - 275 Plus - atomikcarbon.com
