mullen119 said:
I agree with squash. A spring that gives you proper sag with no preload is going to perform better then a lighter spring that is preloaded. If your are preloading a spring, you are doing so because the spring is not the correct spring for your weight. Preloading should be used if you are in between springs, not as a tuning technique.
Interesting, what happens if you can not get full travel, but you have correct sag and no preload?
Like any vehicle, it must have a proper rate spring to perform well. Sag and preload are two of many parameters to dial in a vehicle. These guidelines for preload were not carried down the mountain on slabs of stone, not my suggesting some is needed or yours saying none is ideal.
So back to my first statement, the two of you say the best setup is a book derived sag and zero preload. The OP rides his bike and it hops around under braking and never lets the sealhead touch the cushion on big hits. Now what.
On the flip side, same spring, same good sag numbers but the suspension drops to deep into the stroke, now what, add preload or up the spring rate.
What if the suspension design is based on a falling rate, what if the design is rising rate.
Far to many parameters to just say zero preload and perfect sag...you need to swing a leg over her and see how she feels. As for preload being a tuning aid, yes, it can give the subtle changes to alter frame angles or place linkages or whatever moving components into a better sweet spot, tuned for each rider.
Also as the OP asked, what about making a clicker change, yes altering the control of the damper will have an effect, but would you take out a lot of damping to get full travel but let the bike hop around, or would you make it harsh and deflect to prevent bottoming.
Sorry but I won't be sailing on your ship, the seawater moving across the decks may have dampened them, and we would need to clean them with a damp mop. Couldn't help it, I had to, love your little siggy.
PK
