Component | Year | Model | Weight | Units | Notes |
bar | 2002 | Easton EC70 | 125.0 | g | 580 mm x 3 degree sweep, no rise, carbon fiber. |
bar ends | 2003 | Extralite UltraEnds | 54.0 | g | Black. |
bottle cage bolts | 2004 | Maverick American | 6.0 | g | (4) M5 x 16 mm, alloy. |
bottom bracket | 2004 | Race Face Dues XC | 111.0 | g | X-type, includes L, R, sleeve. |
brake (F) | 2003 | Formula B4SL+ | 228.0 | g | Pump (Al), caliper (Al), line (cut), bolts (Al), pads, oil. |
brake (R) | 2003 | Formula B4SL+ | 240.0 | g | Pump (Al), caliper (Al), line (cut), bolts (Al), pads, oil. |
brake rotor (F) | 2003 | Formula B4SL | 123.0 | g | 160 mm steel rotor, (6) steel bolts. |
brake rotor (R) | 2003 | Formula B4SL | 97.0 | g | 140 mm steel rotor, (6) steel bolts. |
cassette | 2002 | Shimano XTR CS-M950 | 210.0 | g | 8 speed ak (11-13-15-17-20-23-26-30), including lockring. |
chain | 2003 | SRAM PC89R Hollow Pin | 250.0 | g | 104 links, including masterlink, lubed. |
chainring (large) | 2004 | Race Face Deus XC | 89.0 | g | 4 bolt @ 104 mm, 44 teeth, ramped & pinned, aluminum. |
chainring (middle) | 2004 | Race Face Deus XC | 45.0 | g | 4 bolt @ 104 mm, 32 teeth, ramped & pinned, aluminum. |
chainring (small) | 2004 | Race Face Deus XC | 23.0 | g | 4 bolt @ 64 mm, 22 teeth, aluminum. |
chainring bolts (inner) | 2004 | Race Face | 4.0 | g | (4) 8 mm, alloy. |
chainring bolts (outer) | 2004 | Race Face | 8.0 | g | (4) 8 mm with nuts, alloy. |
chainstay protector | 2004 | Maverick American | 0.0 | g | Included in frame. |
computer | 2003 | Sigma BC800 | 33.0 | g | Computer (w/battery), sensor (wired), Shimano spoke magnet. |
crank arms | 2004 | Race Face Dues XC | 523.0 | g | 175 mm, 4 bolt 104/64 mm. |
crank bolts | 2004 | Race Face Deus XC | 21.0 | g | Drive side bolt (aluminum), washer (steel), cover (aluminum). |
derailleur (F) | 2004 | Shimano Dura Ace | 103.0 | g | Triple, braze-on, model 7703. |
derailleur (R) | 2002 | SRAM X.0 | 207.0 | g | Medium cage. |
derailleur hanger | 2004 | Maverick American | 0.0 | g | Included in frame. |
fork | 2004 | Fox Float 100 RLT OE | 1612.0 | g | 100 mm, disc-only, 194 mm steerer. |
frame | 2004 | Maverick American ML-7 | 2502.5 | g | Size medium, anodized black. |
grips | | Schwinn Stinger ATB | 53.0 | g | Clear, cut down, includes bar end plugs (generic). |
headset | 2004 | FSA Orbit CF Carbon | 62.0 | g | Includes cap & bolt. |
hub (F) | 2003 | Chris King ISO Disc | 165.0 | g | 32 holes, silver. |
hub (R) | 2003 | Chris King ISO Disc | 306.0 | g | 32 holes, silver. |
hub skewer (F) | 2002 | Nashbar | 30.0 | g | Bolt-on (steel, black). |
hub skewer (R) | 2002 | Nashbar | 35.0 | g | Bolt-on (steel, black). |
miscellaneous | | | 5.0 | g | Zip ties, grease. |
pedals | 2003 | Crank Brothers Eggbeater S | 270.0 | g | |
rim (F) | 2004 | Stan's ZTR 355 | 368.0 | g | 559 x 24 mm, 32 holes, black. |
rim (R) | 2004 | Stan's ZTR 355 | 369.0 | g | 559 x 24 mm, 32 holes, black. |
saddle | 2002 | Selle Italia SLR | 140.0 | g | Ti rails, black leather cover. |
seatpost | 2004 | Easton EC70 | 215.0 | g | 30.9 mm x 400 mm, carbon fiber. |
seatpost clamp | 2004 | Maverick American | 0.0 | g | Included in frame. |
shift cables | 2002 | Gore RideOn Ultralight | 75.0 | g | |
shifters | 2002 | SRAM 9.0 Shorty | 167.0 | g | 8 speed, w/Amy grips. |
shock | 2004 | Maverick American | 0.0 | g | Included in frame. |
shock bolts | 2004 | Maverick American | 0.0 | g | Included in frame. |
spokes (F) | 2003 | Sapim CX-Ray | 139.6 | g | (16) 258 & (16) 260 x 2.3/0.9 mm, stainless steel, black & silver. |
spokes (R) | 2003 | Sapim CX-Ray | 139.6 | g | (16) 258 & (16) 260 x 2.3/0.9 mm, stainless steel, black & silver. |
spoke nipples (F) | 2003 | Sapim Polyax | 11.1 | g | (32) 2.0 x 14 mm, aluminum, black & silver. |
spoke nipples (R) | 2003 | Sapim Polyax | 11.1 | g | (32) 2.0 x 14 mm, aluminum, black & silver. |
star-fangled nut | | | 11.0 | g | Steel. |
stem | 2003 | Syntace F99 | 101.0 | g | 120 mm x 6 degrees, including titanium bolts. |
stem spacers | | | 4.0 | g | (2) 5 mm x 1.125", carbon fiber. |
tire (F) | 2003 | Panaracer Fire XC Pro | 557.0 | g | 26" x 2.10", folding, blackwall. |
tire (R) | 2003 | WTB WeirWolf 2.3 (52/58) | 744.0 | g | |
tire seal system (F) | 2003 | Eclipse A126U | 125.0 | g | Rimstrip, valve, tape, 75 grams sealant, air. |
tire seal system (R) | 2003 | Eclipse A126U | 125.0 | g | Rimstrip, valve, tape, 75 grams sealant, air. |
TOTAL | 10.84 | kg |
