1 - 20 of 64 Posts
Discussion Starter #1
Am I asking for a trip to the dentist buying some chinese carbon handlebars? Saw some for like $20 in the 150g range.. tempting to try, but if it's going to cost me a few teeth, maybe not.
Any known good riser handlebars that are light? Trying for like 50mm rise ~700mm wide
There are some sold by BXT on eBay. They are light and very inexpensive. i think they are called the HB002. I have the flat bars from them and they are very nice and the risers are on their way. I also have the riser bars from Dengfu and they are a bit heavier (200g). I am going on my 4th year with these are they have been flawless. for reference i am 250lbs and ride rigid SS, so these bars take a beating.
The only time you are guaranteed a dental visit is the easton or race face branded bars selling for $25. the companies that have their own brand have from my experience been very solid options.
One guy around here mentions that broken bars are most commonly due to over-tightening, which is an interesting point, probably some truth in it. I bought some risers from BXT, they look very nice, I've got them on an old Klein 26er at the moment, but I have to admit I don't have any rides on that bike yet, I have pushed down on the bars a bunch, and they seem fine. I've had good experiences with bxt frame, and two seatposts so I thought I'd try their bars. My impression is that bxt is doing a decent job with carbon.
I'm suspicious of what seems to be a common belief that all 'generic' or off brand China carbon forks or bars are an accident waiting to happen, but I also don't want to be the test dummy. I did buy a 'bontrager' 27.2 seatpost for super cheap off ebay a few years ago, it was really light, like 180g or something. I used it for a while, but the single bolt clamp slipped during a race, and I can't have that so I changed it out for a 2 bolt clamp. I gave it to a friend, he was running it up pretty high and he snapped it off during a race, so I agree on avoiding brand name too-cheap carbon.
Discussion Starter #4
wow I would think Bontrager (trek), Easton and Race Face would be more reliable than lesser known brands. Thanks for the tip on BXT. The bars I was looking at are from Tideace, which some people seem to be happy with their stuff on here.
Still a little wary of any handlebars with unknown quality control but I guess if the brand names aren't any more trustworthy then you're always just taking a chance.
The 'brand name' issue is with the fakes coming out of China; a real Bont/Easton/RF will be great, but the counterfeit stuff is to be avoided. If you think you're getting real Easton for $14.99...
It's the axle
I just bought one of these in flat bars. Some of these Chinese parts are really high quality. I sourced parts that look to be the same manufacturer as companies that brand them, like Enve or Thompson. I've been buying machine tool parts out of China, and it's very obvious that some are the exact same parts as from major companies who simply mark them up.
We'll see.
Discussion Starter #7
ah ok that makes more sense.. but still make me wonder about the other bars that are $15...
I bought a Race Face carbon flat bar from China for $20.00 shipped. It was advertised as a 760mm bar it measured 769mm. I have it on my China carbon 29er hardtail with no issues.
The BXTs are $15 and they have been working great. I think a lot of it comes down to intended use. Can a bar be made perfectly safe for $15? yeah, it just may not be a bar that you want to run on a world cup DH course. the $15 bar will have 98% the strength and stiffness of a high end bar (sometime i honestly thing they are the same but for arguments sake). the last 2% is needed in areas that i will never go. just like XTR vs XT, is it better, yeah but i am not, nor will i ever be at a level that will need that difference.
As long as i am buying from a brand that is selling under their own name i don't worry about it. Tideace has a large enough following and reputation that they are not going to purposefully produce bad products.
I have to evaluate the risk---so for me I only run aluminum bars----the weight saving and any damping is just not worth it to me as a failure can be a real issue--I get the allure to save some grams and the named bars are crazy costly but once you break a carbon bar riding and lay on the ground it makes one question the advantages---wheels for sure--frames fine but for me not bars. My 2 cents
I've broken several aluminum bars, they are far from fail safe.
I agree one can break any bar-----just feel the odds favor the aluminum bar---especially when the ask is for a lite weight carbon bar----
The only bars I've broken were aluminum, but that was a long time ago and bars were very skinny near the stem at that time. Those had fatigued and a small crack grew, right at the edge of the stem. I hit a very small water bar on a flat sandy section of an otherwise rough and fast dbl track descent (no injury), the right side just disappeared and I was down before I knew what happened. I'm no engineer, but carbon won't fatigue like aluminum does.
I've got a really old set of Synchros alum bars on my trainer/shed bike with a lot of time on them, I feel like I need to replace them just because of their age.
Yeah that was my opinion, and I'm still sticking with it.
Last year I sold more than a dozen of these handlebars on craigslist and I had four guys who all broke their bars almost right out of the gate. I took the time to meet up with them and do a replacement (which worked out with three of the guys, the other guy was pissed off) and I was able to check bolt tensions of brakes, grips, and shifters on two of these bars. On both of those bars the guys had tightened their brake levers with a long allen wrench and compressed the fibers. Long story short, I told these guys to tighten their stuff to the handlebars just enough that it wouldn't move and none of them ever had an issue as far as I am aware. This is true for ANY carbon bar.
I was also skeptical of chiner bars at first but have been riding them happily for a long time. I never broke one, and have had some nasty crashes, clipped trees, stabbed the bar into the ground, hit rocks, and ride aggressively.
I've settled on BXT bars for everything. The only brand I'm aware of that makes genuine junk is FCFB, I splintered a bar just banging it on the floor.
Compliance and shock absorption in a bar is also proportional to it's horizontal strength. Going with a really thick carbon bar reduces compliance, and it's heavier. I like light and compliant bars, so why pay more?
I will roll the dice on cheap Chinese frames, rims, seatpost, etc... But not stems or handlebars. No personal experience with anything bad, just piece of mind.
Formerly of Kent
I recently bought and received an integrated road handlebar from a well-reputed Chinese brand.
So far, so good. I installed it on my Chinese frame/fork and did a couple of dips on it, full dressed body weight. A little bit of flex and I could see the tire deforming (25mm road tire that expanded to 29mm on my wide road rims), but nothing other than that. That's far, far more than it will ever see during normal riding with my feet on the pedals.
I might be tempted to try what appears to be a Syncros Fraser IC SL lookalike next.
Discussion Starter #17 (Edited)
I decided to try my luck with an $18 "Toseek" branded riser bar. There were quite a few reviews on amazon of a similar looking bar with another random chinese brand with people saying it broke upon installation with a torque wrench, but no reviews for the Toseek one. So we'll see. I don't do any drops or jumps or anything but I'm still a little wary.
edit: the bar with reviews of cracking ones was actually a listing with a variety of different bars, so it's hard to say if this one is a risk based on those reviews
XC iconoclast
happybuying88 Full Carbon Fiber Mountain Bike Handlebar Bicycle Riser Handlebars Riser Bars 3K Matte MTB Handlebars Carbon Fiber
$31 on Amazon
142 grams, 700mm (they have options between 580 and 760mm)
So far so good, and I have a ton of 'clutter' as you guys call it, on the bars; they are holding up fine. So much clutter I had to get slightly smaller 5.5 inch grips, check out the picture lol. E-Bike Handlebar.jpg
Is dang happy!
If the bars have a bunch of flex and are wide and light you are rolling the dice. My Asiacom bars disintegrated while testing them out in a parking lot. There may be some budget jems out there but those were not one of them.
I have a FR01 chiner frame set up for gravel grinding and just built up a BXT for mellow XC trails but would not hit the gnar with them expecting good results. Read reviews and go with something that has many other guinea pigs sort out the good from the bad.
(The bar that broke snapped at the bend and not near any clamp so it was not an installation error)
1 - 20 of 64 Posts
