1 - 8 of 8 Posts
FIRENZE rulez !!
planning to save some weight from this part
i need only f and r derailleur , no brakes
i have now GORE RIDE ON
very happy of switching gear
where find some tips to go down in weight ?
which are the lightest set ? and which better ratio weight/performance ?
nokon carbon , powercordz , jagwire ?
PurpleIsFasterThanRed!
Nokon 33g/m , Alligator 27g/m...
...or maybe my favourite Shimano SIS? 33g/m while costing ~1$/560mm. Yep, it's not sealed as well as two above neither made of shiny-bling-bling aluminium.
Cheers
vi3dr0
Banned
eliflap said:
i had ALLIGATOR I-LINK gold on my previous scalpel ...
but mine , when applied force to shifting, are subject to carve ...
and very noisy ....
so I-LINK will not be consider in my choice
sorry - what is carve?
and there is absolutely no noise as well. you must have installed them in a strange manner. the only noise i could imagine is at the cablestops in the frame. the endcaps are aluminium so when you turn the handlebar it might make some noise if you have sand or dirt in your stops. other than that there is absolutely no noise.
Nokon carbons are ca. 35g/m...but for sure a lot of blingbling;)
FIRENZE rulez !!
Discussion Starter · #5 ·
i'm talking about alu I-link , as your picture
in gold color
when installed , and is no possible to make mistake , was as a possible paly from each section...
and no stable in its position: when i asked for a shifting , i could see an important change of position ... i added other sections, i subtract ... i did many changes to reach a normal situation as stock housing ...
1 - 8 of 8 Posts
