Editor's Note: This review was originally published on June 18, 2016.
Longterm Update: March 13, 2017
After a full year of abuse, our test pump developed two issues. The first hiccup was the gauge. It stopped working. This didn't affect inflation performance, it just meant we had to use our hands (or a digital gauge) to test for pressure before rolling out. That's inconvenient, but not a deal breaker. Gauges fail, regardless of brand.
A replacement part is available through the Lezyne website for under $20. However, this issue was covered under their two-year warranty. All it took was an email. They sent out a new gauge, some Loctite, and detailed instructions.
Shortly after the gauge failed, the ABS2 chuck also died. Well, it didn't die so much as it exploded. We were able to put it back together, but it unraveled again. According to Dillon Clapp, the Global Communications Manager, this issue only affected early units. They made a running change to production which has since resolved the problem.
If you have a similar problem, send Lezyne an email. They'll send you a replacement under warranty. Once you have the parts, swapping the head takes less than two minutes.
Lowdown: Lezyne Alloy Drive Pump and ABS2 Quick Connect Chuck
The new ABS2 quick release chuck from Lezyne works so well it pushes a good product into the field of extraordinary. Read on to learn why.
