Conti Rubber Queen 2.2. Huge grip, size and grin on your face. Only thing that this tyre doesn,t like is mud. It doesn't shed mud well.
You have a large variety of tires to choose from if you're using 2.1 tires for 'AM' riding. Which side of AM do you take to more said:The AM riding I will be doing will be rocky, loose and fast.
From reading some of the threads, it sounds like the most popular combo is Conti MK 2.4 Front, RK 2.2 Rear. Does this sound right?
That's the combo I ran all last season and it worked great. Some people have problems with the supersonic sidewalls but I have run my bike through a lot of big rocks with no trouble. I also ran MK 2.4 front and 2.2 rear and I prefer the RK 2.2 in the rear. All the recommendations above are pretty spot on for what you are looking for. Rubber queen, nobby nic, MK,etc. If you get the conti's just make sure you get the larger carcass models, 2.2 RK-Rubber Queen and 2.4 MK. The 2.2 MK is OK but not great.From reading some of the threads, it sounds like the most popular combo is Conti MK 2.4 Front, RK 2.2 Rear. Does this sound right?
Funny you have found this as the NN have paper thin side walls that fold and pinch flat form my experiences in rocky stuff. For a 2.25 they are kinda skinny too.AlexRandall said:I've ridden recently in Sydney, which has a lot of loose sharp rocks over sandstone bedrock plus deep sand, drops, roll-offs. The Nobby Nic was THE tyre for those conditions. The knobs tended to bite well through the loose surface, and the stability of wide side knobs helped in the sand. I'm not sure what your specific conditions are, but if they are like what I've described then the NN will do well. The wider 2.25 tyre gripped better than the 2.1.
I'm talking about the UST version - The 2.25" NN is a nice width and very wide. I didn't particulary enjoy the cornering performance, but they were okay. The rubber wore very quickly and the sidewalls were garbage. I tore holes in mine in not a very long time, but that's the price for light UST tyres.AlexRandall said:I've ridden recently in Sydney, which has a lot of loose sharp rocks over sandstone bedrock plus deep sand, drops, roll-offs. The Nobby Nic was THE tyre for those conditions. The knobs tended to bite well through the loose surface, and the stability of wide side knobs helped in the sand. I'm not sure what your specific conditions are, but if they are like what I've described then the NN will do well. The wider 2.25 tyre gripped better than the 2.1.
It's not that you don't have an ultimate solution, it's that you have several excellent options. You need to examine what kind of riding you'll be doing, take a look at the tires, and the options for the models, and then pick whichever one looks best to you.pbbullpup said:so.. what I'm hearing is that there is no ultimate solution for what I'm looking for.
:thumbsup:bad mechanic said:It's not that you don't have an ultimate solution, it's that you have several excellent options. You need to examine what kind of riding you'll be doing, take a look at the tires, and the options for the models, and then pick whichever one looks best to you.
