How tall are you? It is about saddle height vs. fork length plus head tube length vs. stem/handlebar setup.
(I do not think HT angle has any influence. On steering: Yes. On the range of possible positions on the bike: No.)
If you are very tall, you should be able to get lots of saddle-bar drop with a 100mm fork, a reasonably sized head tube, a down turned stem and a flatbar.
At the other extreme, if you are small, the only way to achieve any saddle-bar drop at all is a shorter fork, frame designed with a short head tube, low stack headset, no spacers under the stem, a down turned stem and a flatbar.
What you can do is search for a frame that most of all is the correct size for you and the short head tube, low stack 'hidden' headset and a 80mm fork that can be set to 100mm too (RS, Fox). If you find your handlebar sits too low, you can allways add a handlebar with rize, travel to the fork, spacers under the stem (if you did not cut the steerer tube too much) and turn the stem upwards.
So, the question on your answer depends on your saddle height and the amount of saddle-bar drop you want, but think twice: There are possible downsides to a low and forward position. Get it too low and bike handling will suffer. Get it too far forward and your leaning on your arms a lot and there is a risk of lower back issues.
Get fit on a bike by a good fitter!
