You are supposed to use 5 ml of float fluid in the air side of my fork (2012 Float 32 RL 80mm). I note I just can't get the last 5 mm of travel. I had the issue where the the Fox oil was leaking past the seal and into the air chamber..this reduced my travel and changed the spring rate until I dumped it; I have since replaced the seal so hopefully the oil migration issue is done. Can I just use 1/2 the amount of Float fluid to give me a little more air volume to help with that last 5mm of travel? Isn't it just to lube the piston?
Sent from my SCH-I545 using Tapatalk
