Hey all, not been on the forums for a while - as my lefty has been in good shape
That has all changed as of last night, when I tried to reset the bearings and the thing basically fell to bits
. So, I'm looking for a few bits of advice (apologies in advance for not knowing the correct terminology for fork parts).
When I pulled the wheel down doing the reset, something looked like it was poking into the fork boot. Inspection showed that it was one of the long metal strips that run down the fork, it had come loose from its collar and the needle bearing set had fallen out - I retrieved it from the boot and it was broken into 3 bits. Elongating the fork, and the other 3 long metal bits came out along with the bearings.
The top picture shows that the metal O-ring is split (is it meant to be?), and the upper metal collar is bent. It is a 2004 Lefty speed DLR2. The bottom picture shows the metal strips I'm talking about and the broken bearing holder.
So: Did this collossal F-up happen because of a cack-handed bearing reset? (I've done it before many times without problem)
How easy will it to be to fix? There is a very good guy in the UK who basically handles every lefty in the country, as pretty much all LBS's have raised the white flag by now. So I know he'll be able to handle it, but i wonder how big a job is it?
Is it worth upgrading to a new lefty? You can pick them up 2nd hand for reasonable money here. My fork has had a lot of work on it over the years - I wonder if the cost to fix it now (approx £150 probably) might be better spent on getting, say a 2007 or 8 model for approx £300.
Cheers for any advice
