1 - 3 of 3 Posts
So I looked up the pdf instructions and it specified 155ml. I followed the instructions of cycling the fork to get all the oil out of the damper. Just to clarify I have that foam piece tie-wrapped to the compression damper. Anyways, I put 150ml in the fork and when I put the damper back in, oil started overflowing even before I was able to thread on the bottom cap of the fork.
Is that normal??? I was thinking that maybe the idea was to make sure there were no air pockets in the fork but it's still a little strange. Either way, when I press the fork down, about halfway through the travel I feel a little 'clunk' in the stroke. What do you guys think?
Clunking sound...
Two thoughts on this...
You may not be getting all the oil out of the chamber and you are over-filling it. I recently did a quad seal replacement and took the lower cartridge out. I was surprised out much oil was behind the cartridge even though I'd cycled the fork numerous times. When I put 155 CC of oil back in the fork, it did NOT overflow when I replaced the bladder. Fork works great. (Note: I cycled the fork several times prior to putting the bladder back in).
Second - See the picture below. I suspect the crimp connection on the valving cartridge may be responsible for the noise you are hearing.... It is held by 4 equally spaced punch marks. It will get play in it and move both sideways and up and down. I re-staked mine last time I had it apart using a punch and hammer. Fork is quiet after clunking for years.
1 - 3 of 3 Posts
