So I just recieved my new Lefty (Thanks tmachalek!)...
I want to install it myself, and I've worked with this kinda stuff all my life, but there's a few questions...
1-Removing the present headshok: I'm told a headshok is pressure fit into the headset bearings, and a rubber mallet (with proper frame support, etc etc) from the top breaks it loose and out the bottom. Yes?
2-Installing the Lefty: It looks like the DLR cartridge must be removed from the leg, then you loosen the top clamp and take it off. Lefty (with lower bearing already on steerer) then goes in from the bottom. Top bearing is then press fit over the steerer with Cannondale tool (or PVC pipe). Yes?
