I have seen pics of an adapter to put a lefty on a 1-1/8" headset. Don't think the factory advises it, but it was done. Anyone know who made this set up?
http://www.project321.com/no nancies said:Anyone know who made this set up?
True, but not as nicely done, and it requires permanent, irreversible modification of your fork, not so cool. YMMV.eliflap said:on ebay , from a Canadian seller , you can find another adapter
cheaper but heavier , 260 gr
I used a 110mm carbon. The axle to crown (A2C) was the same (within about 2mm) of my Fox F100X which is what is recommended for the Blur XC. I gained 10mm travel to the same A2C) I also specifically wanted a unit with the Terralogic valving.badboy said:Could you share the experience and if possible post the outcome? I got an intense 5.5 and would like to do the same transformation on it. Btw, which lefty have you installed?
A couple of years ago I installed a 140 Lefty Max on my 03 Turner 5-Spot. Easy installation. No problems then, or since. I've ridden the bike hard and the Lefty has worked great.badboy said:Could you share the experience and if possible post the outcome? I got an intense 5.5 and would like to do the same transformation on it. Btw, which lefty have you installed?
