I'm having trouble trying to set sag. According to the manual you should try to get 25% sag, but it seems that I get little to no sag. I've tried swapping springs with one that is below the recommended for my weight, and while the lefty seems to absorb much more (compred to virtually nothing before) I still get virtually no sag. And there is no preload on the spring, if I pull it out to adjust the sag there are a couple of turns on the adjustment before it touches the spring. What do I need to do, is this normal, or is there something wrong with the lefty? Thanks in advance for any help.
