Looks great. Can you provide a measurement from the center of the front hub to the top of the headtube where headset is pressed in?
Looks like 620mm... just FYI the axle to crown is 505mm on the Lefty and 515mm on the Fox F29 120mm... so I dropped the front end 10mm with the same amount of travel :thumbsup:1-bar said:Looks great. Can you provide a measurement from the center of the front hub to the top of the headtube where headset is pressed in?
That sounds like a righteous setup and I love the idea of having 120mm of travel with the A to C close to a 100mm fork. Can the lefty to be dropped down to 100 and how is the lockout on it? I'll have to go measure my setup to see how much it would raise it over my 100mm fox fork. I've got my TB at 23.15lbs and I'd love to improve the shock performance and drop 3/4lbs doing it.CactusJackSlade said:Looks like 620mm... just FYI the axle to crown is 505mm on the Lefty and 515mm on the Fox F29 120mm... so I dropped the front end 10mm with the same amount of travel :thumbsup:
Keep in mind when you reduce the travel the A2C stays the same. Let me repeat that, stays the same. All you are doing is reducing the travel, not lowering it's overall length. This is unlike what you would do on like a Fox fork.1-bar said:That sounds like a righteous setup and I love the idea of having 120mm of travel with the A to C close to a 100mm fork. Can the lefty to be dropped down to 100 and how is the lockout on it? I'll have to go measure my setup to see how much it would raise it over my 100mm fox fork. I've got my TB at 23.15lbs and I'd love to improve the shock performance and drop 3/4lbs doing it.
I wonder if a guy put put a gloss clearcoat on the matte carbon for a shinier look w/o warranty worries?Variateur said:Before I pull the trigger on a Lefty fork, could someone please post some pics of a Tallboy with a lefty fork? Side view, too, pleeeease.
Thx in advance!![]()
I like the Matte Carbon better. Stealthy and chips in paint don't show as much.Variateur said:Before I pull the trigger on a Lefty fork, could someone please post some pics of a Tallboy with a lefty fork? Side view, too, pleeeease.
- What's that little ditty weigh???hugelick said:I like the Matte Carbon better. Stealthy and chips in paint don't show as much.
