If the lights on, the buzz buzzes, then you may have a low oil situation. Does it lock out at partway through the travel? All the motor does, is open and close a small window through which the oil flows. If the motor is working, the only other option is that the drive shaft has broken. If that's the case, get a DLR, you'll be a bit poorer, but alot happier=
