My Lefty DLR has performed flawlessly on my Rush for the last 2 months, until today. I noticed after the ride that there is a pronounced top out "clunk" with no negative spring as though the fork is topped out completely. As a note I have a medium Rush, it has the blue negative spring and I run about 100psi pressure for my 140lb weight. Previously the fork had some negative travel.
I take it into the LBS and we deflate the fork, with almost no pressure there is a negative spring, and when we take the cartridge out everything appears OK. The owner thinks (and it makes sense) that the negative spring has become soft over a couple of months. I have never heard of this happening and have run Fox and Manitou forks with negative springs in the past without this happening.
I was wondering if anyone else had experienced this problem, and if our diagnosis could be correct, or if there is anything else that could explain this problem. We are ordering new negative springs, but with the 24 hours of Old Pueblo looming I cant afford for the fix not to work.
Interestingly a team mate is having the exact same problem with the Carbon SL on his Scalpel.
Kevin
Kevin
