1 - 6 of 6 Posts
ARCHQUEST
I bought a used Cannondale Jekyll with a lefty and want to remove the fork for servicing but after lossening all the bolts on the dual crown so the strut can slide up and down the double clamps but I still can't get the steer tube to slide out of the head tube. Am I missing something here? Should the steer tube just slide out or I need to tap a little with a hamme which I don't feel comfortable with.
Any suggestion helps, thanks.
Hybrid Leftys aren't real
CabezaShok said:
im in the same boat..... i dont have a bike stand, so is there another safe way to secure the frame whilst hammering the headshok out?
Have a friend hang on, tightly.... And don't forget to hang onto the fork as you're hammering. FWIW, it's generally more than a "tap" too. As long as your mallet is soft faced, beat it with a fair degree of agression :D
ARCHQUEST
Discussion Starter · #6 ·
Thanks for the advice, I'll give it a try with the wood block, I'm just afraid it might a small pin I have to remove or something which if I force it will caused damage.
1 - 6 of 6 Posts
