1 - 2 of 2 Posts
Hello everyone
What is the internal damper Lefty pressure chamber utility ??
regarding the internal construction with the pdf document from Cannondale, it seem to preload the oil cardige pressure
is it only to make final damper filling easier ? as I think that internal oil volume is pretty constant, even as the shaft moves ....
or could the pressure spring "strength" make the damping different (using a hardier or softer spring) (I don't talk about negative spring)
if anyone knows ... :thumbsup:
1 - 2 of 2 Posts
