Are you still using the two piston dual lock out RockShx Poploc?Lockout is hard to push from so much pressure in the damper. If I let the air out, it's still hard to push. My damper has already been sent to Cannondale for this. It happens when it gets warm out.
It is available for aftermarket sale now. My distrobutor has them in stock. If you keep the Rock Shox Monarch you'l need to change to the single pop loc lever anyway for that unit as the OCHO lock is cable actuated.I want an Ocho, I asked last week to purchase one...Cannondale said not available. If I didn't have a nice new carbon front wheel, I'd be considering switching to RS or Fox.
you need to service it more regularly. Its based on a RS Solo Air cartridge thats a Oil emulsion system. Its dead easy to service and maintain, a lot cheaper than a IFP design. keep your hand on the servicing and it won't treat you poorly.Neglect it and well .......now you knowIt's 85deg here and without any use, my 2.0 has pressurized just from the heat. It did this last year too and got serviced for that very issue. What a crappy design!
About 100 hours and it is not the dual, it's the single xloc. You still didn't tell me the maintenance you are referring too...how many hours in those 4 months? (I hit 120hrs in 3 months)
Is it still fitted with the dual PopLoc remote?
to the fork servicing. It would appear that if you're servicing at about 100hrs then you may want to be having a conversation with your cannondale dealer around who services your Lefty. At my LBS most 2.0's only om back after 120hrs and then it a gradual decline in performance.About 100 hours and it is not the dual, it's the single xloc. You still didn't tell me the maintenance you are referring too...
