I hate you.2611 said:
/just kidding
I hate you.2611 said:I registered for Leadville this year and sure enough hit the lottery.
Agreed, power to weight is everything, which I profoundly resent! I am 6'4" so I already know I wasnt born for this sport. I raced Leadville last year at almost 195lbs :eekster: Finished just over 8:20. Plan on racing this year at 180lbs and shooting for 7:44:26 (give or take). I'll also be on an 18lb rig becasue your bike factors in to the power to weight ratio right.KERKOVEJ said:Power to weight. Tech skills not needed as mentioned above. Big a big engine strapped to a lean body build.
Acclimate if you can.....obviously, altitude is the biggest challenge for the 1,000's that come from out of state.
http://lwcoaching.com/?p=1094
That is a very precise time, give or take, where did the 26 seconds come from?ErrantGorgon said:Plan on racing this year at 180lbs and shooting for 7:44:26 (give or take)
I followed Eatough's program to the T last year, and all went well. Other plans mentionedon this thread should be great too. I think the key is to follow whatevr program you select.chuckie33 said:Are there any good commercial plans available for a 100 miler? I've read about Chris Eatough's plan and I'm considering purchasing that. I like to keep it as simple as possible. Tell me what to do on what day and I'll go do it. I'm not big on HR monitors and trying to stay in particular zones. If there is a plan that is less complicated, I'm all for it. Any suggestions?
I read on his site that no HRM is needed. I'm fine with using one if it makes the plan easier to follow. Did you use one with his plan?EBrider said:I followed Eatough's program to the T last year, and all went well. Other plans mentionedon this thread should be great too. I think the key is to follow whatevr program you select.
It should be achievable without a hrm, but I have no idea why you wouldn't use any tools available.
I did. I think it helps estimate intensity-chuckie33 said:I read on his site that no HRM is needed. I'm fine with using one if it makes the plan easier to follow. Did you use one with his plan?
