I've converted the SpeedDisc AM which is basically the same profile using Gorilla Tape. The handy roll is the perfect size and costs $2.99 a roll.swengo86 said:Can my stock laserdisk wheels be converted to tubeless using the yellow tape and rim strip? I want to run tubeless but don't know whether I need new wheels to do this or not. Thanks
So you didn't use the yellow tape or a rim strip at all? I could go pick that up at any Home Depot or Lowes I would suspect....correct?mtnbiker72 said:I've converted the SpeedDisc AM which is basically the same profile using Gorilla Tape. The handy roll is the perfect size and costs $2.99 a roll.
http://mtnbiker72.blogspot.com/2009/08/gorilla-tape-tubeless-pics.html
Correct, just the Gorilla Tape. The handy roll size is found at pretty much any hardware store.swengo86 said:So you didn't use the yellow tape or a rim strip at all? I could go pick that up at any Home Depot or Lowes I would suspect....correct?
And as far as tires go.....UST or standard or doesn't it matter?mtnbiker72 said:Correct, just the Gorilla Tape. The handy roll size is found at pretty much any hardware store.
UST and Tubeless ready tires mount up very easy with this setup and you know they bead will work. Standard folding tires can be more of a challenge. They are usually harder to seat and some work better than others as far as holding air. In addition, some folding bead tires may not have the bead strength (I had a standard Bontrager bead snap and explode off the rim with only 30 psi in my garage).swengo86 said:And as far as tires go.....UST or standard or doesn't it matter?
I just took the tubes and tires off to find there is red tape on the rim covering all the spoke holes already. Will that suffice to run tubeless or would you recommend taking that off and re-taping with the gorilla tape or just taping over what is already there possibly?mtnbiker72 said:UST and Tubeless ready tires mount up very easy with this setup and you know they bead will work. Standard folding tires can be more of a challenge. They are usually harder to seat and some work better than others as far as holding air. In addition, some folding bead tires may not have the bead strength (I had a standard Bontrager bead snap and explode off the rim with only 30 psi in my garage).
So if your looking for reliability and minimal work then go with UST or Tubeless Ready (Bontrager TLR, Hutchinson Tubeless Ready, Geax TNT, WTB TCS, Specialized 2Bliss) tires and a latex based sealant (Stans, Slime Pro, Joes, or make a DIY formula).
The tape needs to be air tight...I'd just remove the existing tape and put the Gorilla Tape down.swengo86 said:I just took the tubes and tires off to find there is red tape on the rim covering all the spoke holes already. Will that suffice to run tubeless or would you recommend taking that off and re-taping with the gorilla tape or just taping over what is already there possibly?
Also, I think it would be safe to say that I can use any standard tire that is listed as OK to use on the notubes website? I currently have standard nevegal's on but I just ordered a ust small block 8 for the rear since my tire has a slit in the sidewall already
OK Great! I got myself a roll of that tape so I'm set. Do you inflate a tube and leave it on the tape to help set it overnight or anything like that? Also, as far as the Nevegal's go, I'm using that as my front tire which I usually run less air pressure anyways.....not sure if that matters or not.mtnbiker72 said:The tape needs to be air tight...I'd just remove the existing tape and put the Gorilla Tape down.
As far as Stan's list...it's only a guideline. He has Bontrager tires on the OK list and that is the one that exploded on me. He has IRC tires on that don't use list and I've used them before with no issues. With Kenda tires I've had mixed results. Nevegals worked no problem while a set of Klaws were impossible to seal (lots of pin holes in the casing).
I'm going to give the Gorilla tape a try first....if that doesn't work then I'll give your setup a shot. Thanks for the advice!loamshreder said:Bontrager rhythm tlr rim strips fit laserdisc trail rims well. $10 for the strip and $5 for a stem, costs more than the tape. Been a good setup.
Do you have a link for YouTube?p nut said:I set up my Laserdisc's tubeless with Gorilla Tape and it's held up all season last year. Haven't ridden much over the winter, but I'm surprised it's holding air as well as it has been. It was hanging for a couple of months and hardly had any air loss.
There is a youtube instructional video on setting this up. I followed that and has worked well for me thus far.
