Finally got everything the way I like it so I thought I would post some pics and build info. The bike as pictured hits the scale at 29.51lbs. Not bad for a 22".
Fatback 22" polished nickel w/ Fatback carbon fork
Uma II drilled rims with Fatback (Hadley) hubs and Ti skewers
Fatback E13 180mm crankset
Shimano 10sp Dyna-sys drivetrain (yes it works with the E13 crank)
Formula R1 disc brakes w/ Ashima rotors (180/160)
Thomson seatpost, stem and seat collar
Specialized S-Works carbon riser bar
Specialized Phenom SL Ti saddle
Twenty6 Prerunner Ti pedals
Cane Creek 100 Headset
Ergon GA1 Leichtbau grips
Surly Larry/Endo tires 120tpi
Q-tubes super light 26"x2.4"-2.7" tubes
